Gobblin Tom
Nice Tom:thumbsup:
Could you cut them and weld them back together?
Greg
Yeah probably do u think they will work like that?
Nice Tom:thumbsup:
Greg
If you're able to get them pretty much exactly the same,I don't see why not.
Greg
Tom,yeah I guess you could use them longer,but you're going to end up playing around with the height to try and get the holes to line up.
Greg
As the two surfaces on the lift arms and the lower brackets wear on each other the 3 point won't lift the mechanism up as high as it used to and a fixed length device will no longer install easily
Any special painting procedure you recommend?
I have had good luck just using Rustoleum paint that I apply to the steel after heating it up.
