GreenWannabe
Platinum Member
Sorry about that table in the above post, didn't paste like i was hoping, it came from the link that Greenwannabe posted....
...which is part of why I linked to it instead of posting! The forum software reduces all spacing and tabbing to a single space. That can make a table very difficult to read.
In regard to your question on spacing, the lift arms are adjustable, so that part shouldn't be a problem. It will require that you adjust them from the width you use for your other implements, though. You do need to remember that equipment designed for a cat 1 hitch can be very easily pretzled by the power of a tractor with a cat 2 hitch (especially a ground engaging implement), or overwhelmed by the hydraulic lift power of the larger tractor (lifting equipment like a boom). The cat 2 implements are generally built stronger to match the stronger tractor. Best suggestion is to be safe, make sure you are not overstressing cat 1 implements. Good luck.
