Jcarr
I too bought one from Iowa Farm Equipment, who are good people to do business with. I had some pretty big (3' plus) cedar stumps to grind. These things are hard and full of dirt in the core. The trick is aiming the grinder. It really helps to have a spotter. The swing of the unit will often not cover the area of a large stump so you need to learn to make all of the "missed" areas on the same side of the cut unless you just like repositioning the tractor. Also, don't try to take too much at once. My experience is not to engage more than 1/5 to 1/4 of the cutter outside diameter at once. Therefore you must take down the stump in layers. My tractor's listed weight is about two tons plus the rear tires are filled with water. I jam the FEL down firmly and set the brake before grinding. Shaking was minimal.
Also, the unit is furnished with a 1' floppy hydraulic hose that connects the regulator of the horizontal swing line with the return. Called Worksaver and found that the length wasn't part of a dampening scheme so I replaced it with a brass pipe that I threaded through the empty large diameter hole just over the cat 1 center attachment point. Makes for a neat installation!
This things works great and doesn't tear up the landscape like a dozer or backhoe. Just pile all the chips and dirt back into the hole and it is gone in about six month as the dirt is washed down out of the chips. After the six months is past, I just run over the mounds with my Rhino SE 6 shredder and viola, all is gone!
