oldpilgrim
Elite Member
I've had my BH on and off several times, and left it off all winter. Today I went out to put it back on and it took me nearly an hour to get everything lined up. I was really getting pizzed. Normally it takes about 5 minutes, but the fates were against me today. Once I had it just right, I moved the bucket lever and 'clunk' it went right in as easy as pie. It was just trying to find the right combination of boom movement and stabilizer movement to get everything at the right angle so it would drop into the upper and lower attach points at the same time. If I did it more often, it would be easier I know. BTW, it sits on the concrete floor of my barn on wooded blocks so the starting position couldn't be better.
I took it out to remove a rock that sticks out of the ground about 6 inches right at the edge of my dirt driveway. I dug beside it, and around it and when I had it uncovered completely, it turned out to be 9 feet long, 5 feet wide and I stopped digging when the sides got dug down to 4 feet.
Just a bit big for my little tractor. I filled in the hole and will have to grae the driveway differently so as to minimize the effect of the rock.
Other than getting some seat time, it was a wasted afternoon.
