soulasphil
Platinum Member
For the sake of comparison, the John Deere 3520 weighing 1316 kg (2 900 lbs) without cab has a Maximum Static Vertical Load of only 255 kg (562 lbs) on the drawbar.
Anybody know what the tongue weight capacity on the drawbar of my 3510 would be? Sure dont want to crack my rear casing.
Didn't mean to slight you or ignore the data you posted from your tractor's manual. Perhaps I should have said "currently publishes max drawbar tongue weight in its advertised specifications..."Now you know two. I just gave you what the Ford manual stated to use as a guide. When you look for the specification, look for "Maximum Static Downward Load" under/in drawbar section. But you are probably wise to derate the Ford spec for your tractor.
Your drawbar attachment scheme looks much safer than the one on my 3510.The downward component of the tongue load is carried by the rear part of the support bracket below the drawbar. The upward component of tongue load is resisted by the front part of the bracket above the drawbar. The tongue load is transferred to the tractor structure via the two pins that attach the front part of the bracket to the tractor structure. There are two bolts that attach the rear of the bracket to the tractor structure.
The pulling load on the drawbar is transferred to the tractor via those two pins and the pin that attaches the front end of the drawbar to the bracket.
I would be happier if Mahindra would include tongue load limit and drawbar pull info in the ops manual. Wonder if they have that data (how about it Mahindra dealers?)
