If you want to do a lot of PTO type work with larger equipment - get the turbo.
But, that being said....I have a 3320 (with loaded tires) and live at 5,000 feet altitude. The tractor can easily spin all four wheels if I fill up the box blade heavily - turbo won't buy you extra traction. Granted, I don't live in an area with heavy soils or clay - and, that may be different.
Secondly, the load match feature is in one word - unbelievable. I had a 60-inch rotary cutter on the back of the tractor; and was cutting down large 4-wing salt bushes. I was in the middle of one that was about 5-feet high, 6-feet wide, and had 1-inch and larger branches. I had forgotten that I had put a bail of straw near the bush at one time that I was using as ground cover in seeded areas.
In the interim time period, the bush grew over the bail hiding it. I hit the straw bail with the cutter while I was in the middle of the bush. The tractor automatically slowed down, diverted power to the PTO - and I cut the bush and shredded the bail simultaneously.
I'm sure the turbo and a cab would be great...I just don't plan on doing a lot of PTO work beyond doing a bit of rotary cutter work. After two other tractors of the same PTO rating - the JD load match system just blew me away.
