JB4310
Super Member
A concern is are the hoses long enough to allow it to set on a block and how much of a distance and angle of the dipper stick be required as space is limited where I park this? I'll find out shortly.
I wouldn't fret over using the stabilizers and not the 3pt, you'll hear from those who are more experienced that it's just easier, maybe even safer.
You want to plop it down on as level an area as possible I have a plank aprx 2x12x36 under the back hoe, and yes the hoses are plenty long enough, no real difference there as it drops the same distance no mater by what means.
As far as the boom goes, you want to put the lock pin in to prevent any movement, dipper should be brought in tight also, the bucket can be let down so the flattest part is parallel to the ground. I put blocks of wood in the bucket linkage to prevent it from folding up and getting the BH out of position.
Also if space is tight and you store other things next to BH then you want to tie the stabilizers together to prevent them from dropping down over time, possibly damaging something.
