dapper
- Joined
- Nov 17, 2005
- Messages
- 285
- Location
- S.W. Ohio
- Tractor
- NH TN-65, Ford/NH 3430, Ford/NH 3930, Kubota zd21
Evening All,
Thought I would take advantage of the nice weather here today, do some maintenance I have been putting off till summers end, and clean up all my equipment. A couple of to-doe's for the 3930 were putting a new fuel filter on & changing out the antifreeze. Cleaned the sediment bowl, and got the new filter installed and bled with no problems. :thumbsup: So I continued on and checked the antifreeze. Fluid checked good, but don't know when it was put in, or changed, so thought I would just change it out and I would have record of when it was done. Should be simple drain and fill right??? OK!!! But wait! I cant find a drain cock for the radiator! Checked every place it should be, but no drain. Pull out the books and they show drain cock on left side of radiator at bottom. WRONG! Not on my tractor... Book did say that "some models may have drain cock in engine block instead". WRONG! Not my tractor!!!I do have a plug where the book shows a drain cock, but not sure if this is the correct plug or not. At this point I'm not confident enough to remove it. Even checked on NH website and they show a drain cock on left rear of radiator, right where the book says mine is located... WRONG!! I know I could just take off the lower radiator hose and do it that way, but thought I would ask the "experts" here what I was missing?? Should there be a drain cock somewhere, or do I need to change/drain by taking plug out of engine block? Is there somewhere else I should be looking?? Might have missed something/somewhere?
BTW: Book also stated that NH "inhibitor" should also be added at antifreeze change, so I will have to pick up some of that. My NH parts man LOVES me! :laughing:
Appreciate any input.
