CBW1999
Platinum Member
- Joined
- May 11, 2008
- Messages
- 836
- Tractor
- Kubota 7510, Toro Groundsmaster 217D
I know you said $10000, is that cash available- or all you are able to finance?
Kubota has some really good financing available right now. You can include Land Pride implements in the package as well, so you could start out with the equipment you need.
Several years ago, I bought a 7510 with FEL and 54 MMM for $13000 (new). I run it on 5 acres (mostly hilly/rough)- but couldn't be happier. (although I try to convince the wife i need something bigger...)
If your soil is easily workable, then the 20hp range might do you well. if you run the right implements, I think you would be happy.
I have seen similar used tractors with some "toys" in the 10000 range, if you work on the dealers and do your research, I think you'll be able to get set up well.
