If you are willing to do a little troubleshooting, I may be able to tell you if your problem is injector pump timing related. Your tractor has a Bosch injector pump. The pump has two electrical solenoids on it. The one nearest to where the fuel line comes in near the top is the fuel shutoff solenoid. Power is applied to this solenoid whenever the key is ON, which allows fuel flow. The other solenoid is located at the rear where the injector lines leave the pump heading to the injectors. This is the KSB solenoid. When 12v is applied to this solenoid, the internal pressure regulator is over ridden, which basically advances the pump timing more than normal. At the front of the tractor, just above the battery, you will see a blue timer/relay that says ' TIMER KSB ' on it [ well, on my tractor, anyway ]. When you first start your tractor, this timer applies 12 volts to the KSB solenoid for a period of time [ 20 minutes maybe..?? ]. Your mission, if you think you can do it in a safe manner, is to go start your tractor, let it run for a minute, then pull this timer out... [ practice with the motor off would be a good thing ]. This shuts off the KSB by removing the 12 volts to it. If your motor then starts to miss like you described, then your problem is injector pump timing related.... if not.... well then move on...
