Have a 414 Inter tractor which is losing almost all hydraulic pressure due to
the fact that almost all the oil is being dumped though the Slow/Fast control
port much this is caused by the absence of a piston & spring which are almost unobtainable.
Any opinions on blocking the Slow/Fast port which appears to be a bleed
off arrangment as far as I can make out, this should be easy enough done.
Thank You.
Thank You.
