I put my 4300 in the shed last night to do some work on the mower.
Went out today and found a small pool of oil under the right rear tire.
Appears to be hydrostat fluid. It looks like it may be leaking out the right end of the axle housing and down into the inside of the wheel, then to the floor.
I do not know how long it has been leaking, but if it leaked out that much over night I would think I would see some drop in the oil level. With the tractor running the sight glass is empty, immediately after turning it off the sight glass is almost full. I am leaving it set again tonight to check it again tomorrow.
Any words of wisdom? What may be wrong? What will it take to fix?
Thanks in advance. James
