I just signed an order for a 4500 P. I added the three point hitch with hydraulic top link.
Question: What purpose does the Three N One serve? Does any one recommend it for someone who likely be using a box blade for upkeep on a gravel driveway?
Question: I purchased the power bucket with grapple. Can I attach that to the three point hitch? If so, if I get the additional hydraulics for the rear will it allow me to use the power bucket from the three point hitch? My use case is use the brush cutter. Inevitably I will run into something that I can cut with the brush cutter. Use chain saw to cut that down. Then use the power bucket and grapple on the back of the tractor to pull out what I just sawed down.
My use case is brush cutting on a property with 20 to 45 degree slopes. I also purchased the trencher as I want to irrigate 5 acres.
Thanks in advance
Martin
Thanks in advance
Martin
