JC-jetro
Elite Member
Don't worry about a column of air in the hose, we are not troubleshoting a nuclear reactor
Good one Rick, I'll sure make a note of it for future reference.
JC,
I did not think about throttling down before disengaging the pto and am glad to learn this. I will probably get a chance to get a gage and adaptors Monday and do some checks.
Today I bought a pressure gage and attachments to check the pressures for the pto control valve and pressure regulator valve.
The recommended pressure is 220 psi at 2300 rpm and 200 at 1000 rpm with the pto lever disengaged and higher when engaged.
My reading is 190 psi at 2300 rpm and 180 at 1000 rpm with it disengaged and 250 psi at 2300 rpm with it engaged.
What do the experts say about these readings?
IMO, knowing practically nothing about hydraulics, I think that these readings are close enough for it to perform well if there was not something else broken.
The pto hydraulics are supposed to turn on the pto brake when the lever is disengaged and engage the pto clutch and release the pto brake when the lever is engaged.
The pto hydraulics are turning on the pto brake when the lever is disengaged and releasing the pto brake when the lever is engaged but my pto is not turning.
I am fearing that this means that my pto clutch must have broken teeth or some other mechanical broken part that means that my tractor must be split.
[/B]
I know of no other tests I can perform and I surely can not split this tractor to rebuild the pto clutch.
Does anyone have any suggestions for me?
If the tractor must be split and the pto clutch rebuilt, does anyone know ABOUT how much a NH dealer would charge?
I am not an expert, but I seldom shy away from an opportunity to submit an opinion. .
We all have an opinion sometimes.. but.. I think it's safe to say that for all intents and purposes.. you are an expert. too much evidence here and in the 'other' forum to not say so.
soundguy
