jim_wilson
Veteran Member
- Joined
- Jun 13, 2004
- Messages
- 1,781
- Location
- Northeast MA
- Tractor
- Kubota B3200 w/ BH77 & 12", 18" & 24" buckets, Kubota B50 SSQA w/ 54" & 60" buckets, LandPride FDR1660, Artillian Fork frame, Extreme 3pt rake, Concrete Mixer, MyTractorTools grapple adapter
Thank you for all the great inputs.
Time and Money.... I ain't got enough of either.
We are going up this weekend and I will get some pictures to post.
I am pondering the situation and discussing the options with "She who must be obeyed" :thumbsup: Today I am thinking that renting a large loader/backhoe for a week or two would be best. I would take vacation for that time so as to maximize seat time. Buying would be reasonable if I could get a couple hours of work done during the week and weekend, but I'm not there during the week & don't get up there every-weekend.
Never rented anything that I couldn't haul back and forth myself. What is involved? What should I watch out for? Delivery fees? Setup charges? Insurances?
I am playing out too many scenarios in my mind. I agree now that a large BH is the right thing for now. I am thinking renting for the "brute force and ignorace" work is better than buying. A smaller TLB then could do the "finer" detail of back filling the foundation and helping build the rock walls.
So much to do, so little money. Time is on my side although I don't get to spend as much time up there and I would like.
Thanks for the input and keep the information coming.
So it sounds like you've got a very similar problem to what a lot of people have. Not enough time, money, or foresight into what you will actually need to get the job done.
I had a similar problem but on a smaller scale. We bought a house - in a suburban area - and I had a bunch of work I wanted to get done. I started out as a new homeowner doing stuff by hand and occasionally renting out equipment to get specific jobs done. After doing that for a couple of years - and coming up with an extensive list of stuff I wanted to get accomplished - I sat down with and wrote down all of the jobs I thought I would have to get done - and what type of equipment I would have to use to do it. Not necessarily what type of equipment would get a job done the fastest - but whether or not I could actually get it done at all.
Then I looked at how much it would cost me to buy, vs. rent ,vs - pay somebody to come in and do the work. And everything - other than the fixed cost of buying the equipment - was pretty much just an estimate. Buying came in the most expensive - IF , the equipment was worth zero at the end of that time. Paying for somebody and renting equipment was pretty equal if I remember correctly.
So I ended up buying a BX23 - mostly because I was somewhat cost constrained from going to a larger tractor - and also because at the time the backhoe solutions available for the B series were sort of lousy in my opinion - they were all subframe backhoes that hung off the bottom of the main frame. THe BX23 actually had more ground clearance than the B7610 I looked at with the backhoe subframe hanging off of it.
After using the BX23 for a while - I renting some mini-excavators - I learned that excavators can definitely get more digging work done - but they're not going to be moving much dirt anywhere. I also learned that having a backhoe that only goes 140 degrees - is a bit of pain in the butt. After using hte BX23 for a few years - I upgraded last year to a B3200 with BH77 hoe. Yes - the bigger tractor definitely gets more work done in less time- and can move bigger rocks.
My solution for really large rocks I can't move - is Dexpan. I just split them into smaller pieces. Dexpan is cheaper than equipment rentals - for me anyway.
So if you're budget constrained - I would say get the largest contractor quality TLB you can afford - but you've got to realize that certain things might take longer to get done than if you had a larger piece of equipment. So you've got to balance time against available money. If there are rocks that are just simply too big to move with whatever tractor you get - then you can just save them all up for a rental day or weekend and a large excavator - or you can split them and move them with whatever TLB you get.
Other than large rocks and really deep holes - I can't honestly see anything you CAN'T get done with a TLB like an L39 or an L48 - it will just take you longer than it would with a larger piece of equipment.
The other thing to bear in mind is - the larger the piece of equipment you get into - the more money the attachments you might want to add onto it will cost. So you want to add a box blade to an L39? A really nice one might cost you $1500 new. If you get into a much bigger piece of equipment - it's going to take a larger box blade - whose cost will go up proportionately.
So getting the bigger piece of equipment has constraints too - because you might be able to afford to outfit the smaller tractor with a more diverse set of attachments - that you won't be able to afford if you get a bigger tractor.
Plus attachments of a size that will work on an L39 or L48 - are reasonably commonly available on Craigslist - you will have a much harder time finding them for a larger tractor - and you'll have to go to MachineryTrader or one of those type places - and you'll pay premium prices for everything.
Just a thought.............
