SkyPup
Elite Member
- Joined
- Dec 3, 2003
- Messages
- 3,005
- Location
- North Central, Florida
- Tractor
- Kubota L-39 GST TLB, Kubota L3130GST, Massey 1030 HST, Kubota ZD-21 ProDecK, Two Euro VW TDIs
</font><font color="blueclass=small">( Ive just completed my 50 hour service with everything but changing the hydraulic fluid. I was wondering since the hydraulc fluid does not wear out like the engine oil how important is it to change it at this early interval )</font>
The specific reason that you need to change the oil out is that hydraulic filters are different from crankcase diesel engine oil filters and diesel engine fuel pump filters, the hydraulic fluid operates under completely separate conditions.
Hydraulic filters have to provide allot more flow (gallons per minute) than either a diesel crankcase oil filter or a diesel fuel pump filter, without creating excessive backpressure.
This requires that the capacity and filtration orifices in hydraulic filters be much larger than either diesel engine oil filters or diesel fuel pump filters. Typically engine oil filters provide 8-10 micron filtration at the best, while diesel fuel pump filters provide about the same, however hydraulic oil filters are nomially about 80 microns or so for filtration orifice size.
The primary size of the destructive abrasive steel particles in modern diesel engine motor oils are < 5 microns, same in diesel fuels, and same in hydraulic fluids. So your hydraulic filter at best only removes the largest chunks out of the oil flow to keep them from ruining the hydraulic pump, which is a sensitive close tolerance device, similar to your engine and fuel pump.
Quite often, the best way to remove the <5 microns abrasive particles from the oil that escape the filtration devices (<80 mocrons in hydraulic filters) is to use a magnet to capture the steel residue, although all of the residue is not always ferrous.
Change the hydraulic oil now @50 hrs like your manual states instead of changing the hydraulic pumps and being sorry later.....
