Soundguy
Old Timer
- Joined
- Mar 11, 2002
- Messages
- 52,238
- Location
- Central florida
- Tractor
- RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
87 octane fuel is fine. octane in the 50's was much lower than it is today... these engines are low rpm, low compression.
I'd run a heat range higher on the spark plugs due to the cruddy gas we have. thus champion h12 / 512 vs oem h10 al437 are good too.
lead addative? why? Tetra Ethyl Lead was originally added as a octane modifier. ( PS.. ethanol is an octane modifier too! )
save your money on the snake oils.
your machine left the factory with hardened valve seats. if you want to add soemthing to the gas, go buy a 2.50$ quart of walmart type F atf and add a few ounces to the fuel every tank.
as for oil.. ? run a 15w40 C rated (diesel) oil.. it will have more zddp in it. though any old jiffy store 10w30 is better than what was around in 1950..
