rambler
Veteran Member
- Joined
- Jul 6, 2003
- Messages
- 1,992
- Location
- MN
- Tractor
- Ford 960, 7700, TW20, 1720; IHC H, 300; Ollie S77
What hp is your tractor? 10 or 15kw is a pretty good load. It is possible you will be lugging a <25 hp tractor pretty badly if you run it at less than full throttle on that load.
This would _greatly_ increase the wear on the engine.
What is max engine rpm for your tractor? Generally it is more than pto speed.
You should be able to run pto speed days & days on end at rpm speed. It's what a tractor is designed to do.
Lugging the engine - now that is hard on them. If you put too much load on it at 1/2 throttle, it won't be able to get into it's torq bubble, and the poor thing will really strain. Combines come with a throttle much like a lawn mower - pretty much idle or full throttle. No need to ever be in between, and not really good to be running in between.
Hardest of all is starting them. Most folks don't realize leaving it run an extra 20 minutes is better for them than stopping & starting them....
If you put a multiple belt pulley on the pto shaft & apply enough pressure to eliminate slippage, you will be deflecting the pto shaft & putting a lot of wear on the tractor pto assembly. Likely to wear that out rapidly. You would need a supporting pillow block, & it is difficult to line one up perfectly, so you need to put in a flex joint of some type & 2 pillow blocks on your jack shaft.....
A vbelt is equally as dangerous as a chain. Do not forget this. Ever. The teeth look worse. But the belt is every bit the equal on catching someone. I have too many 9 or 5 fingered neighbors.........
Not saying you don't have a good idea, but if you think it all the way through, things were meant to run one way.... Be sure to look at all the considerations.
--->Paul
--->Paul
