pitt_md
Veteran Member
to have that much planted in alfalfa you will be right around $600 $800 if you prep the field yourself. I just did 7 acres. Next you will need to fertilize it every year, where I am thats 200 lbs. of potash/acre and 100 lbs. of ammonium sulfate/acre. pot ash is currently $82.50/acre and ammonium sulfate is $23.75/acre. Then you get to pay to have it spread only $5.50/acre.
Next comes harvest time. I found a guy that will cut and rake for $20/acre, and large square bales are $9.00/bale. For 6 acres with a good growth you will get around 20 - 25 bales first cutting and 15 - 20 for second cutting. You would need to check the price for large squares in your area to see if this will be worth you while. Oh I almost for got, you will need to build a pole barn to store your crop in. Figure on $8,000 - $10,000 for the size needed if you have a bare bones storage shed built.
I forgot about equipment needed. Your going to at least need to get a tiller and a set of forks for your FEL. You do have a FEL don't you? Good then its only going to cost you about $2000 - $2500 for a good tiller and set of hay forks.
Still interested???? If you answer yes, seek help immediately!
