Thanks for the feedback. I'll try to answer most of the questions in one response.
I would be cutting grasses and if/when needed wild flowers for control of weeds. Eventually I can see mowing the 3+ acres of wild flowers annually in fall just for appearance, unless there is a reason not to.
I do not have any brush to deal with (at this time).
smstonypoint: The real world tire width is close to 61" tread to tread. I don't know if the dimension from TractorData is for Ag tires, or is just wrong. So, unless the 60" model really cuts 60" (I suspect it would be more like 58"wide,) there will be an issue with material laid down and not cut without a generous overlap on the next pass. I could be wrong, maybe they actually cut the width stated.
Could you speculate on why the HC model of a 72" would only require 20 HP? That unit is a model designed to compete with many other low cost units. However, your still swinging a 72" Blade back there and unless the gear ratio and blade speed make that much difference I would think the HP requirement would be the same.
I sure don't want to have to crawl along in order to keep PTO speed at design RPM.
