ADin
Bronze Member
Some more data,
I wasn't able to break the nut loose on the middle sheave (no corrosion, just too dang tight) and would also just loosen the blade nut underneath. So I left it and I cleaned and sharpened blades, and reassembled everything. Improving the 1 sheave I could get off did not seem to make much difference.
I've been thinking about new experiments the past few days and while I got into a oil change on the tractor today I tried a few of them.
First was to remove the blades to eliminate blade problems and reduce spindle effects - result was no change in flapping.
I then observed flapping at various rpm speeds under no load and without blades. Flapping was still significant across the entire rpm range. At low rpms the tensioner actually appeared to travel further than at higher rpm. To me this all but eliminates the spring as a cause as although the spring is acting as a low pass filter, the oscillations are significantly higher frequency than than what the spring can react to and while a stiffer spring might shift the frequency response up a bit, I don't think it would move it enough.
I also noticed that whatever was causing the flapping had a fixed periodicity to it (not a big surprise) and that changing the rpms slowly I could cause the harmonics to align or destructively beat causing either a near perfect standing wave (near maximum flap travel) or very little flapping. My feeling is that this all but eliminates the belt at a cause. Sheaves are still the prime suspect.
I removed the deck again and studied the tensioner again since I was a bit surprised to see the amount a travel I was seeing at low rpms and I wanted to eliminate the pto as a source. I measured the travel of the tensioner pully as I slowly hand turned the pto shaft. I discovered that I could cause a min to max travel of about 3/16" in about 1/4 turn of the PTO at certain spots in the rotation, but not in the same spot of the PTO rotation. This eliminates the tractor and PTO box as primary source. Knowing that this 3/16" movement over a such short distance by hand turning the PTO will be amplified significantly as the belt speed is increased, I think this has to ultimately be the problem (or indicative thereof).
The tensioner pully movement coorelated to the very small wobble in the middle sheave I was not able to remove before. I went to work again trying to remove the sheave nut and this time with two breaker bars on the top/bottom nuts and a 2x4 to act as a third hand to help hold the blade fixed I was able the loosen the nut. I found this was the worse sheave and that the "thickness" varied over short distances which would cause the apparent sheave radius to grow or shrink. I tried to make uniform, but there is only so much precision one can do with a vise and I didn't dare try hammering. I reassembling and still have a bit of wobble in the sheave. The min to max travel of the tensioner pully is now about 1/8" versus 3/16" before. Not unexpectedly I still have belt flapping, although I believe it may be subtly reduced.
I think I will break down and buy 1, possibly 2 sheaves at this point. Anybody know the cost off hand? Or more importantly where I can find a non-deere cross referenced part. Its no telling what Deere will want to charge for 1 of these sheaves.
Megatractor - I would be curious to know if yours is similar, though perhaps worse. If you get a chance all you would need to do is to just disconnect your pto and hand turn your blade at the discharge side and notice if your tensioner has much travel. I found a small 90 degree straightedge standing upright against the tensioner pully while you rotate makes it easy to see.
Based upon the above, does anyone have any other thoughts or experiments before I drop any money on the sheaves?
