6410, no forward or reverse. LHR problem? 389 orig hours!
   / 6410, no forward or reverse. LHR problem? 389 orig hours! #1
atc007
jd 6410,3255,2950,2940,lots of Masseys : )
Yep, almost broke in. 6410, 640 loader. Plastics still on seat. Went to use it today, will not move. Did it once before, but no go today. LHR seems to be fine and I def hear a relay clicking in the fuse box with every try. The 1,2,3,4 is working hydraulically for sure.My assumption is something down below went bad or can the relay click but not work? I will hopefully troubleshoot more tmrw.
   / 6410, no forward or reverse. LHR problem? 389 orig hours! #2
Can you be more specific?
engine runs but no drive?
No forward/reverse?
No gears?
What type of gearbox?
   / 6410, no forward or reverse. LHR problem? 389 orig hours! #3
With so few hours and having that age on it maybe from lack of use something as simple as a seal(o-ring) broke down?? Sounds like you need tech manual and appropriate gauges and start troubleshooting.
Sorry guys. Full cab, 16 speed power quad, LHR, electronic. Which I have learned now was updated to the newer style after this model. Anyhow, I fixed it. It was a relay. 2nd time this has happened. They are $14 from Deere , Amazon or Ebay, so I put a Deere in it. TY guys!!
