user.69169
Veteran Member
- Joined
- Feb 22, 2009
- Messages
- 1,346
Co2 cylinders use CGA 320 valve connection with plastic washer between valve & regulator.
WARNING there are also cylinders containing something called "Beverage gas" which a mix of Co2, Argon & Nitrogen used on a lot of beer and beverage systems. Absolutely useless in welding unless you need a purge gas to work on a fuel tank.
Difference between a beverage regulator & MIG regulator is volume capacity. Beverage regulator will freeze needle to seat at welding rates over period of time.
Lot of welderbatrers get worked up bout frost on outside of regulator.. Happens, bot meaningless to gas path inside regulator.
Beware of small Hobart ITW regulators on Co2. ITW built dem off shore wid crap brass dat corrodes wid pure Co2 and locks needle up to seat. Real easy to spot because ITW saved 1 penny per regulator by not using thread compound on fittings into regulator body. Dey built to leak.
