LOL! If I used a torch then I'd have to start a whole new thread on how to put it back together again! :confused2: :silly:
Are both hinges mounted the same direction with the pin head facing the left? If so, you can simply take a small 3 or 4 lb hammer and knock the gate sideways tapping on the right side until the pins come out. Or you can take a small hammer and a screw driver (or cold chisel) and hit the inside head of the pin like you were trying to knock it out and the pin should start to move.
Thanks, the zerks both face the middle. So I'll try to knock out the pins banging on the zerk ends.
Maybe my best bet is just to lay the ramp down inside the trailer if it'll go, or even vertically weld the angles on without even messing with the hinges.
Gracious - such an easy fix gone sooo awry!
