Dr_Zinj
Veteran Member
A tractor, at it's most basic, is a machine that pulls stuff. In fact, the earliest tractors were actually tractor engines; basically an engine on skids that drove a winch that either pulled a plow on a cable across a field, or pulled the entire engine another furrow over. That's about as universal, stripped down, and no frills as a tractor gets.
Now I suppose you mean a tractor on wheels. Basic and stripped down; as such, you don't want any added hydraulics, no cab, no lights, mechanical brakes, clutch transmission, no 3-point hitch assembly, and no PTO. Are we thinking of an old Model A Ford or Willy's Jeep with no body? If so, I'd recommend just buying a used Jeep Wrangler and put a tow hitch on it. I'm also assuming an agricultural or small acreage setting; and not an industrial one.
You see, the correct way to buy a tractor is to list the requirements you want one for. Then check all the manufacturers and models to see which meets those requirements. The one that meets those minimum requirements then becomes your "stripped down" base model. If you are thinking stripped down equals cheap, then you have two choices. Wait a long time before something that meets your physical requirements also meets your financial ones; or buy something that meets the financial constraints but doesn't meet the physical ones. But if you can't meet your physical needs, it doesn't matter how cheap the tractor is, you wasted your money, you made a bad deal, and you'll hate yourself for a long, long time.
