Coyote machine
Super Member
- Joined
- May 4, 2009
- Messages
- 7,660
- Location
- Southern VT
- Tractor
- 22 SANY SY 50U, '10 Kioti DK 40se/hst KL-401 FEL, loaded tires, KB-2485 bhoe, Tuffline TB160 BB, Woods QA forks, MIE Hydraulic bhoe thumb & ripper tooth, Igland 4001 winch, & GR-20 Log Grapple. Woods BBX72" Brush Mower. Diamondplate aluminum canopy
Your weight makes virtually no difference in the overall equation. And loaded tires contribute to ballast, but not enough to overcome the cantilever effect of the FEL hanging off the front end. Use 4x4 whenever you might slide, slip or other wise loose traction you would otherwise be able to use to get you where you're going.
If you only have two ranges, high and low, then do all your work in low, and level ground travel or slight grades in high. Use 4x4 for winter in snow, or mud, wet grass, etc., but not on dry hard ground. Use chains for traction on ice or slick snow. Tires and 4x4 won't keep you from sliding on hard packed snow, inclines or ice. Keep your COG (center of gravity ) low with the bucket low enough to not adversely effect your control over the tractor.
A box blade will add some ballast, but with your slopes something heavier might be needed, like a barrel attached to the 3PH with concrete in the barrel to give you better balance and ballast. Time will tell. Use your ROPS as designed, DON"T tilt it, and use your seatbelt and brakes to slow your momentum on steep terrain. Anticipate what you will encounter and keep yourself positioned so you are less likely to have a roll over by not crossing slopes side to side.
Show us some pictures of your site so we can add other useful tips. If we haven't seen pics it never happened!
