Propylene or MAPP gas as it is branded is not much better than propane. I havent used propylene in over 25 years and cant remember if you can gas weld with it or not but for sure you cant with propane. You need the same type of tips to use either gas. Propane you can get in lots of places and dont need to find a welding supply open on weekends if you run out, or deal with the LWS to rent the bottle in the beginning. Once you buy your tips you are finished with the high priced LWS. I dont know the costs differences between the two, but I would suspect that propane is a cheaper but the convenience of it makes all the difference. I have been thinking of getting a propane tip for my torch just in case I run out of acetylene. I have a spare O2 bottle but only one acetylene. I usually have propane for my BBQ pits available and if not, its readily available 7 days a week at several stores in my area.
