Here we go again - Or Not!! This is the approach I took to solve the cylinder creep problem
I installed this little guy on my tilt cylinder -
3/8 NPT 8 GPM BRAND PC37C PILOT-OP CHECK VALVE
I first ordered a dual pilot operated check valve as I mistakenly thought it would be simpler to install, but it was physically too large to fit nicely. I'm no hydraulics expert either, but it's not really all that complicated to install one of the above valves if one has a modicum of mechanical aptitude.
I mounted the single pilot operated check valve's outlet port directly to the lower (ram side) port on the cylinder using an adapter - this mounts the valve solidly, the other two connections to the valve are by flex hoses. On the top cylinder port I installed an inline "T" fitting and ran a hose to the pilot control port of the check valve. Locks up tight as a drum yet is completely controllable from the cab or when standing behind the tractor hooking up an implement (I can reach through the back window to the control levers so no need for rear mounted levers). This solution, costing about $75 total for valve, hoses, and fittings, is IMO better than an adjustable needle valve or undoing quick connects to lock a cylinder. The single disadvantage is that after you shut down the tractor moving the control lever will not allow gravity to move the cylinder as that requires positive pressure on the pilot port to "unlock" the check valve.
Not having installed a pilot controlled check valve before, I did not know if there was a preferred location for the restricter orifice, after or before the check valve (I'm using a .032" orifice on both top and tilt cylinder to slow things up some for more precise positioning). Asking the techs at Surplus Sales got the telephone equivalent of a blank stare - they had no clue. So I installed it closest to the cylinder inlet (i.e. between the POCV and cylinder) - - works fine there, cylinder runs smoothly with no jerkiness loaded or not. Note that the single POCV I installed only prevents creep in the extending direction - so far gravity prevents creep in the other direction. The top cylinder I purchased from Surplus came with a DPOCV already installed. Excellent quality
2X8.25X1.18 CAT I HYD DA TOP LINK CYL
bumper
If anyone wants pictures of the install, just ask.
