Thats great, thanks for the link! But why did you go to all the trouble to tie into the back? Whats the benefit versus tying into, what seems to be, the much easier to access front connection?
Also, I found a cheaper single spool valve on Bailey's website but their terminology is a little different. It says tandem center, which I believe I have translated to open center, right? But it says 4 way, nothing about power beyond. Would this be the same thing? It appears that basically the pressure comes in, is either diverted through A or B to extend or retract the cylinders, or passes through the open center and out the other side. Would this be correct?
And one other thing. This particular valve doesn't appear to have a pressure relief. Is this necessary or does the factory one protect the entire system?
