That sounds easier than what I was going to do. I found an older post from 09 that posed the same question and here is what was told to him
"This is really a straightforward and clean deal.
With the backhoe removed, you normally connect the jumper hose back onto the tractor so the hitch works after you move your two handles to allow flow to the hitch and open the tank port.
Take the QA hose and connect it to your aftermarket valve stack P port (pump/supply) - you can have as many valves/circuits as needed. The valve(s) must be open center type and able to handle 11 GPM flow at rated engine speed and 3000 PSI rated pressure.
The power beyond (PB) port or the return from the stack then has to be plumbed where the QA hose normally connects on the tractor.
The auxiliary valve stack / Top n Tilt will be upstream of the hitch circuit so it is important to attach is as above."
What I am going for is to be able to have a remote at the back of the tractor when the backhoe is off. I would possibly be using the remote with an implement on the 3 pt. hitch so I was trying to figure out a way to have the use of both at the same time. Mostly I will be using the remote for hay rake and tedder, they both have hydraulic fold for transport, the only other thing that I would possibly use it for is a post driver.
I found a picture of one that was done previously and they said that they had full function of 3 pt. with the valve.
http://www.tractorbynet.com/forums/...d1012583368-top-n-tilt-5-105697-pdc_00232.jpg
I think that I will plumb it like this the only difference is that my valve will be mounted up front and I will have to run the inlet, outlet, and the 2 remote lines to the back.
