belah
Bronze Member
Does anyone know how to adjust the governor(or if it can be adjusted) on a 1992 Kubota M4030su. I am turning a Winco 25kW PTO generator and when my home ac unit(5 ton Trane heat pump) tries to start,it boggs the engine down and doesn't start the ac. Winco said that i needed 2hp/kW so the tractor should start and run the ac unit. It seems like the governor is not kicking in when the load is applied. I am running the engine at 2200 RPM to get 540 PTO RPM. I have turned a 4 ton grinder/mixer fully loaded and still grinding without problem. Also,i've talked to other people who turn this generator with smaller tractors and their ac unit works fine. Any advice would be GREATLY appreciated. It gets HOT down here in Louisiana!! Thanks Belah:thumbsup:
