gengine
Platinum Member
Extending the tongue on all of your trailers sounds like a bunch of work, and that doesn't solve your problem if you have to pull a buddies trailer. With your trailers, can you put so much weight on the back of the truck to affect the steering that much? I think adjusting your loads in a way to make the trailer axels carry the weight is a better option, with as short of extension on your receiver as you can get. Moving the ball 8" further from the bed will give you more turning ability. Make sure the weight of your load is slightly foreward of the trailer axle(s) so there isn't much weight taken from the steering axle. I don't see any other easy fix.
