I've posted this before...from
Installing Liquid Ballast in Tires | Gempler's
"Tires are designed to operate at maximum efficiency when they are at their Rated Deflection. With the tractor on a hard surface, deflection is the distance from the axle center to the ground surface divided by the distance from the axle center to the top of the tire. In technical terms, deflection is the value of the loaded radius of the tire compared to the unloaded radius. Rated deflection is the amount of deflection when the tire is deformed to its optimum or design footprint. Rated deflection for radial tires is about 85%, for bias tires it is about 90%. The correct pressure to achieve rated deflection depends on the load the tire is carrying. A correctly inflated radial tire will have a significant sidewall bulge or "cheek'. It may look low or flat but it is not. If you inflate a radial tire by "eyeball" until the sidewall bulge looks like that of a bias ply tire, you lose most of the performance advantages of the radial tire.
The tire gauge you use and the way you use it can have a big effect on what you think the tire pressure is. Always start with a good gauge, one that costs money, is easy to read, and is graduated in 1 psi increments. If your gauge cost 99 cents or came free from a feed dealer, has marks every 5 psi from 0 to 100 psi, and looks like it will break if you drop it, you are probably not going to measure pressures accurately.
Ideally, tire pressures should be measured in the morning, cold, or when the the tractor has not been used for several hours. As a tractor is used and the tires warm up, tire pressures will increase from 1 to 3 psi.
If tires have fluid
ballast in them, the pressures at the bottom of the tire can be as much as 1.5 psi higher than at the top, depending on the amount of ballast. Whether you measure at the top or the bottom doesn't matter as much as whether you are consistent in where you measure. It is less messy if you measure with the valve stem at the top but it may be slightly more accurate if you measure with the valve stem at the bottom."
For anybody contemplating filling their own tires for the first time, this site gives some good step by step instructions with pics
There is quite a bit of good information in this site
Installing Liquid Ballast in Tires | Gempler's and this site http://www1.agric.gov.ab.ca/$department/deptdocs.nsf/all/eng9920
