Alternative Fluid for HST Compact Tractors
   / Alternative Fluid for HST Compact Tractors #1
KamloopsBC
Bobcat CT 225
I have about 75 hours on new Bobcat hydraulic/hydrostatic fluid in my 2013 Bobcat CT225 (basically a Kioti). I am reluctant to by more fluid from bobcat if I don't have to. Apart from all of the regular tractor transmission/hydraulic oils out there, I also have good availability for Cat TDTO 30 in my area. From all of my research, all of these fluids are basically the same. I don't think it matters too much on the manufacturer. I need a couple liters on hand for top up with filter changes and small leaks. I would rather not mix oils for top ups, but on the other hand if I don't have to pay list price to bobcat and can get an equivalent that will work why not. I'm sure Bobcat does not make the oil and I know at the end of the day there are only a couple manufacturers for oils, which is no different than fuels. The only difference would be the additives in the blend. Does anyone have any input on this?
   / Alternative Fluid for HST Compact Tractors #2
all tractors ive ever operated list multiple brands of oil int their manuals. my kioti listed kioti brand as well as mobi,shell, and other brands on a chart. they just list the minimum requirements. I have never used Kiotis own oil as its too expensive.
i use Shell Donax-TD in mine.
   / Alternative Fluid for HST Compact Tractors #3
Seems like you’re answering your own question ie. “fluids are basically the same”, “only a couple of manufacturers for oils”, and since you’re worried about buying from the dealer in case you overspend by a few dollars just follow your heart and buy the cheapest oil that you find, even though you don’t want to mix oils. Don’t sweat it…😉
