High Compression
Platinum Member
We built it. It works pretty well. Gotta couple of tweeks to make. Honestly we just copied the "Rock Mountain Bale Sweep" with a couple of minor mods. Rocky Mountain Bale Sweep - YouTube
I had the tranny in anti-stall mode in high range. The computer had to drop to the low side in the high range. I was just thinking, "I think I can, I think I can.":laughing:
Only about 55 acres of that is square baled. The rest is round baled.Your tractor is capable of alot, but baling 300 acres.. I think your due for an M-series. Snag an M7040 before they go to Tier 4!
I played around with it. If I turn off the auto, it just bogs down so bad that I'm afraid that I would stall the engine. So I bump it down manually. I just changed my fuel filter, but maybe I have some bad fuel. Then again, it works flawlessly everywhere else. I even bale in high gear low range with no problems. Who knows? :confused3:Try running with the anti-stall turned off. I believe that this basically automatically reduces your speed to keep your engine RPM's up, but I have found that it seems to overcompensate and drop the ground speed more than necessary. Try turning it off and just back off the hydro pedal as necessary to adjust your ground speed. It might be better to just set your engine speed with the standard throttle vs the auto throttle advance, since when you let off the hydro pedal, you would also be letting off on the throttle when using auto throttle. You may just have bigger hills than I have, but 3100 lbs isn't much weight for a 57 hp tractor, hydro or gear. Give it a go without using stall guard and no auto throttle and let us know how it works. I don't use the auto HDS(?) setting much, which automatically shifts up/down between ranges. I prefer to do this myself with the column lever. These HST Plus tractors have great features, but some of them I prefer not to use all of the time.
The way I see it, if it's called a "tractor" it's meant to work. Although I agree with you to a point, any tractor with a Cat 2 three point is a substantial "utility" tractor and can do a fair amount of work. As for the sport hilling, I can see that could be interesting at times. But I do have 1300 lbs of RimGuard in the rear tires as well as the loader that bump the operating weight up enough to get good traction coming down the gravel road hills with the baler. I'm still cautious though.Wow you guys make yours do more than I would even think of. L5740 is still just a glorified garden tractor. I wouldn't think of pulling any baler around my hills. The baler weighs as much as the tractor, makes for sporting hilling.
