Freakingstang
Everything sure looks good. You said the speed is kind of slow for the cylinders. I wonder if that is a restriction somehow at the valve or adapter. How much does the speed change with respect to engine RPM?
A ton! Its simply not enough pump.. I kick myself for not plumbing in the aux pump for faster cycle times. But, it might be perfectly normal. I'm used to running bobcats, trackhoes, etc....so its a little slow compared to what I'm used to. I'd just rather not run around with the engine screaming... A hydrostat would be nice too...
Of coarse, its six million times better than a shovel and a wheel barrow!
here's some dirty pics after moving some fill dirt and rock into my "lake" hole.
also, that orange front tray slides in my front reciever. I have a 50lb weight and two 44 square weights that I can slide in the rear hitch if I need more weight. It makes a good chain carrier on the front. Guess I should paint it blue instead of the kubota orange since I won't be plowing with it anymore (was a counterweight plate for the little bota)
And here is some size comparison pictures. People dont realize how small the beaver is and what a capable machine it really is.
I think it has come a long way from the airport looking tug when I got it....
