menchhofer
- Joined
- Feb 7, 2005
- Messages
- 184
Was using mini hoe today suddenly the PT lost all forward motion and rolled into the hole.
I had reverse but forward was out. Even though the unit is not to be towed, I pulled it out with my Pick up and drove in reverse to get it into the barn. Also lost speed control in reverse, so to stop it was necessary to shut the engine off.
Anyway, got to poking around at the lever that is attached to the control cable and located on a large control valve (?) seems a bit loose. It has a pin that holds it on the shaft. Pin shows on one side but not the other. Tomorrow I will inspect more closely to see if just the lever is loose. I hope it is as I tried contacting Powertrac today and no one answered.
