beppington
Elite Member
How do you like to set your adjustments up ? Do you change it much or keep it the same way all the time ?
IIRC the blades were set at all 4 corners (front & rear blades & side-to-side) to be 1/4" below the skids, & I've never made any adjustments.
I'm sure you could grade more aggressively by lowering the blades further, to say 1/2", but I've never needed that - Even at 1/4" it can pile up a lot of dirt very quickly.
You can also grade more aggressively just by shortening the top link a little (but not too much) so the front blade is at a more aggressive digging angle. Of course you could shorten the TL so much that you cause the grader to ride only on the front of the skids & neither blade would even touch the ground. And like a box blade, if you want to do a more smoothing job, lengthen the TL so that the rear blade does most of the grading & is at a less aggressive digging angle.
