OP
DMG Tractor
- Joined
- May 9, 2011
- Messages
- 21
Maybe there's some confusion... for both of us!
If he has the 3rd rear-mounted SCV - in your words - a "true rear SCV". AND then installs an electric diverter - which utilizes the hyd circuit of the 3rd rear-mounted SCV - by diverting that hyd flow to the 3rd SCV FRONT loader function; grapple, etc. when required; he won't have to operate a "handle" or even toggle the switch more than once. (Unless he has a rear mounted hyd cylinder connected to the rear SCV.)
Never have to leave the steering wheel, never have to drop your hand from the joystick - AND - he'd never have to toggle between curl and grapple or back and forth numerous times between curl and grapple while loading debris or bales.
Click - front grapple. Click - rear SCV. It's that easy. Curl always works; and you don't have to worry about whether the curl is gonna twist back or the grapple is gonna close. 'Cause if you're like me... I routinely would forget when the curl is on or the grapple is on! And in the heat of working a pile of tree limbs or a pod of square bales; I get curl when I wanted grapple!
AKfish
YES AKfish.. the last part of your description is exactly how i want this to function ....click front grapple... click rear scv.... using a diverter controlled by the electric switch, i also specified that i wanted the loader control knob with the rocker style thumb buttons to control the grapple... I knew what i wanted to be able to do withthe machine just could not describe what the basic configuration had to be... Thank you very much! I feel i can now sit down with the dealer and we can all get on the same page.... once again thanks... lots of valuable info throughout this whole thread.. thanks people
Dave
