The first winter we had our gas hooked up we had the same problem. Only happened in cold weather and has not happened since (4 years now) I'd say it happened around 7 or 8 times that first winter. Fairly annoying having to reset the regulator and I was worried that it would continue.
Never did figure out the reason behind it, but since it stopped after that first winter I guess I just attributed it to the new installation (maybe some moisture or condensation in the lines). I agree that you should check your pressure at the source, we are at about 100lbs here and have seperator before the run to the house.
I really don't know that the well operators "hate " having a dwelling supplied from the well head, but I do know that they are very concerned about liability and have always made it very clear through written correspondence.[/QUOTE
Maybe its not a hate but when the operator knows now,someone is depending on it to heat there house he has more responsiblity to get it back going ASAP. I run 76wells a day and some lower producers get put aside for the better ones,its just gotta be that way having so many to over look,and its not just riding around in pickup we do almost everything,unlike some. I couldn't get to all them if just driving and not doing any work to them,luckly some don't need much attention. Just an example they may only checked it twice a week now would need to check it daily. We also have two wells on farm,different company from what I work and I never see them there,I find stuff when out feeding cows have to call pumper and tell him he might wonna come check this well. Just like every business you have some good ones and some that do enough just to get a check. A seperator will get your water out but if you have wet gas need a dehy to get your dew point% down.
