Another way to do it would be to buy a 15 hp gas engine for the blower. Adapt it onto the snow blower (much easier than adapting the hydraulics), route the power leads to plug into the front of your tractor to energize the electric starter on the 15 hp engine, etc. Heck, if you have a quick-tach bucket on your loader, make the blower quick-tach compatible. This would be the slickest deal going. You'd have a quick switch from bucket to blower, MUCH better than a front mounted blower that required removal of the loader. Hydraulic stuff in my experience costs about twice what you originally estimate. Quite a bit of the cost is in fittings and nice custom length hoses.
What does a 15 hp horizontal engine cost? $450? $500?
I did this!
Found a wisconsin 16 HP, mounted it with crank facing rearward and bolted on blower top.
Used a 3.5 inch on motor sprocket and drove a 10" sprocket on my blower input shaft and designed a tensioner for the drive chain.
The blower was a 48" and the power was more than adaquate.
Being electric start I could start from the cab at any time/location.
I had added attaching points that mated with my loader arms once the bucket was remouved for the winter. Attachement was easy, just 4 pins like the bucket.
If I did it again I'd use double VEE belts rather than chain drive as a tensioner clutch arrangement would not be hard to arrange.
Being non clutched the motor was a bit difficult to start with the load of the blower mechanism. (but it did work out OK)
Visibility 'up front' was the main drawback due to angles and distance, so much so that I ingested a large metal object and totally scrapped the blower.
I since went back to a bit wider rear PTO mount.
The biggest hurdle/problem was keeping the engine from ingesting blown snow especially whenever I blew to the left (where the engine was mounted) so I had to create a shrowd to prevent cold wet snow from contacting the hot engine.
Once overcome I used the rig for the whole season trouble free. (until I ingested that d--m piece of scrap metal).
Still have the !6 hp, and probably will add it to my log splitter. (another project)
