mikehaugen
Elite Member
I wonder if that can cause the tractor to run lean. Seems like it stalls either because its too lean or sucking air. Can running lean . It run hot?
I would think so, but I'm not sure how lean a diesel will actually run?
...snip... so I traced the fuel lines back to the tank. Found the fuel pump and, lo and behold, there was another inline filter between the tank and the fuel pump. But of course there would be. Just makes good sense. I bet he's clogged up. But I think I'm gonna get some line and bypass him just to make sure. Then I can get everything in one order.
Thoughts?
Diesels run leaner than gassers to begin with, sometimes as lean as 120:1 (air:fuel) in the right circumstance on the right engine (that lean it would be at idle). Technically, gasoline engines have the most complete burn at 14.6-14.7:1. Yet max power from a gasser is on average between 12.0-13.5:1. Gasoline engines have come a mighty long way once you look at a Gasoline Direct Injection (GDI) engine in terms of how lean they can run. A carb'd engine might get away with 15:1, where a GDI can do around 60:1.
Here's Mr Kubota's weak stream from the fuel pump.
Wow.
That's awful. I imagine bypassing that filter will solve your problems. It's barely getting fuel at all.
Actually the dealer had one in stock, so I will just change it. Will see about cleaning out tank while I'm at it, but doesn't look bad poking a flashlight in it. Will have to empty it anyway. Got a little extra fuel line at the dealer in case I have to replace some. I wonder if that restriction would kill the lift pump. We'll see.
