TYM Tractors
Manufacturer
You could also consider adding front end weights in order to compensate for the heavy rear attachment.
I will tell you the lift numbers on the 3 point don't really matter that much. Even with a loader on you won't be able to use that hitch capacity unless you get a big bucket of dirt first. My snowblower is a big side chute model Normand that sticks way back, with blower raised the tires barely touch the ground, can't steer on snow unless you fill the bucket. Everything else big I have for the 3 point is barely usable on the small tractor.
As an example my KV AB85 spring reset plow below. Hitches up fine, tractor lifts it without sweat. Front tires barely touching ground, no where near enough tractor to use the plow.
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=361961"/>
Below the blower. I use the blower about 80-100 hours per winter and it runs well, just heavy.
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=361962"/>
Nice pictures but I disagree. In addition to the example I already gave, consider this: your snow blower looks heavy. What if your tractor did not have enough three point lift to lift it up in the first place? You would need to step down to the next smaller size blower. Or, what if your tractor could barely lift it, but mine could handle it with ease... not considering front ballast, just considering lift strength. Mechanically, your three point system would most likely wear out before mine would... or some other stress applied to a different point would present itself.
If we were both bodybuilders or weight lifters, and we were both attempting to pick up a weight off the floor and curl it.... the same dynamics would apply. If my personal weight lift rating was 200 pounds, and yours was 150, and we were both lifting 150 pounds multiple times... you would reach the point of fatigue, stress, or injury before I would.
Anyhow, while both my LS R4047 and my new Massey 1648 cab handle the blade ... the Massey handles lifting it much easier. Not that the LS strained, but i could definitely feel it when I lifted it. The Massey on the other hand, lifts it without even feeling it. It's a noticeable difference.
Might not ever matter... or it could matter in the long term. Like anything else, using something to the end of its limits might have long term consequences, vs using it within its comfort zone with room to spare.
Very well said. The more reserve, the longer the tractor or person or whatever else will last.Nice pictures but I disagree. In addition to the example I already gave, consider this: your snow blower looks heavy. What if your tractor did not have enough three point lift to lift it up in the first place? You would need to step down to the next smaller size blower. Or, what if your tractor could barely lift it, but mine could handle it with ease... not considering front ballast, just considering lift strength. Mechanically, your three point system would most likely wear out before mine would... or some other stress applied to a different point would present itself.
TSO. In your comparisons, do you remember if the joystick control is in the base price of these tractors? My reason for my question, I dont need the loader, only the hydraulic control, for front blade. I thought it would be better to ask these questions in this thread as in the Tier 4 thread. lt190b
