I would guess that the cylinder mount is seeing more load than it can handle, but not gross overloading, causing fatigue failure. I think the old cylinder mount needs to be completely replaced. When you do that you need to "beef up" the surrounding area to aviod moving the problem to the next weak link. These are quick sketches. Old stuff needs to be cut off after carefull measurements are taken on hole location for the cylinder rod end. Add 3/8" plate to the existing thinner plate in the corner of the jaw. Add 1/2" or 5/8" plate at the right spacing for the cylinder rod end (probably 2.5 - 3" inside). drill the new holes in the new plates for the cylinder rod pin. A good quality hole saw will make a clean enough hole. additional gussets back the jaw behind the new plate wouldn't hurt either. If you need more help let me know. Grapplerepair1 is a back view of the grapple, grapplerepair2 is the side crossection.
