My B2620 HST pedal is sticking just a little but it's a big pain because when I get off the seat to change the angle on my rear blade the engine stalls because the relay switch has not tripped and the tractor thinks it is still going forward with no operator even though it is not.
I have adjusted the switch which helped for awhile (and was a big PITA because I had to remove a loaded rear tire to get a wrench on it), greased the S*** out of the rocker arm of the pedal too. It seems like there is not enough return spring pressure to bring back the pedal all the way and trip the the switch. Anyone know if there is an adjustment on the return spring on that tractor? - I can't figure it out while lying in the snow. Help- thanks.
