L355SS
Bronze Member
- Joined
- Jan 20, 2012
- Messages
- 82
- Location
- Mountaindale, Oregon
- Tractor
- Allis Chalmers ACD19, ACG; Kubota BX2200 FEL, B2710 FEL, L355SS FEL; Cat D47U, Ford 4600SU FEL
The 3 pt lift arms on my B2710 are loose on the splines and by removing the ring clip, will slide right off. Anyone else have the same. Is this normal? The tractor has 1200 hours on the meter. I use a heavy pto trencher with this unit and am worried the shaft or splines might strip/break. What is the fix for this, replace both the splined shaft and the lift arms? Are the splines supposed to be a tight fit (I would think so)? It may be that only the lift arm splines are worn.
Dennis
Dennis
