The Gardener said:
... if you are running a B3030 using HST and a 72" MMM [in my case] while riding in its air conditioned cab ...
Gonna pony up all those extra Benjamins for the 72"? Like some of us cautioned you, if your ground isn't real smooth you'll have some issues. Also, no factory bagger for the 72" (if that's a consideration).
The Gardener said:
How [and how often] do you clean the under side of your B3030 MMM?
This is one of those questions that everybody has an opinion on, where there's no right or wrong only shades of orange, like changing fluid X before the manual says to, or hey, B3030 vs B26
Cleaning and greasing are two areas where the MMM manuals leave alot to the imagination (a la "Daily Check"), and there's no shortage of imaginative & creative thinking on TBN.
What I
have been doing (I say
have, b/c lately I've been thinking about some changes) is every 10 hours of MMM use, I take it off, hoist it with the FEL, power wash it, dry it, grease everything real good, and put it back on (or away).
First item likely to spark a debate is the power washer, cause (a) it can take paint off, and (b) you can force water into the bearings. My thoughts are use common sense - (a) set the pressure just enough to take grass buildup off, not "cleave diamonds", and (b) don't spray directly at parts with grease in them. I've yet to blast any powder coat off. Still, water can be sneaky, hence the greasing afterwards which should force any out ahead of the old grease. Sometimes in between, I had put the FEL on to jack the tractor up in front and power wash the MMM on the tractor, but I more or less stopped doing that 'cause 10 hours comes fast enough for me and I don't think this heavy gauge deck is going to rust out anytime soon. Another method I've heard is periodically scraping the buildup off with something akin to a plastic putty knife, but I'm a hair short on the patience for that.
Just what I've done, subject to refinement. Interesting, if you look at maintenance for ZTRs most greasing intervals spec 25 to 50 hours at a time. Regardless, the correct number of hours in any application is the one that keeps the bearings full of mostly-uncontaminated grease. Like I said, you'll probably get alot of good opinions.
