Bad Pump vs Bad Rockshaft Seals Troubleshooting
   / Bad Pump vs Bad Rockshaft Seals Troubleshooting #1
AJoeyH
Eicher 364
Hi all,
Currently working on an old Eicher 364 and having a difficult time with the hydraulics. They worked briefly and then stopped when I tried to bleed them.
Measured pressure at the pump output line is 200 PSI at idle, up to 1000 PSI at max RPM. The manual says it should cap at 2438 PSI.
There are no leaks, and no filter (externally anyway) between the XMSN/HYD reservoir and the pump. I inspected the internals on the pump and everything looked good. Worried that its a rockshaft issue after I used pressurized air into the reservoir to prime the pump. 8 second Video of the reservoir below for noise/fluid spray context.
I know I have an obscure model here but I'm hoping to get any advice on what could be causing the issue. I have a user's manual but not a maintenance or parts manual.
