frugalangler
Re: Battery Charger / Desulphator - BatteryMINDer 12117 $25 - (& comparison to Ebay j
Almost all current generation chargers available today are multi-stage microprocessor controlled (read the package, not all are but are older re-marketed units) and are capable of being left on continuously. The size of the charger doen't determine that, the processor inside does - multi-stage ones will go idle after final charge and if the voltage is sensed to drop, will go into maintain mode until it's brought back to full state. If you need or want a charger for connect and forget look to a current technology marine unit.
Those larger chargers aren't meant to be left connected to a battery for extended periods of time (well, maybe some can do that, but only if they specifically offer that mode). They are meant to hook to a discharged battery and charge it up to full capacity. Then you unhook it.
Rob
