OP
frontyardfarm
I ended up ordering a flail mower a few weeks ago, I've been so busy I haven't had the chance to use it until the other day. It is working great, rips right through really tall grass and weeds. Thanks for all the advice everyone.
This was my first time using the G107d in front mounted mode so it took me a little bit to figure it all out. So far reversing the handle bars is the only thing i don't like about the Grillo. Reversing the handlebars seems a lot easier on a BCS. The Grillo isn't very complicated, but you do have to take apart the gear levers and move the reverse shifter from the top hole to the bottom. Also, the PTO lockout bolt has to be switched around and for me, the clutch lever had to be loosened because spinning the handle bars tightened the cable.
It is not that big of a deal, but i will have to try and figure out if there is a way to avoid having to adjust the clutch lever each time. Also, I am tempted to leave off the PTO lockout bolt that won't let you engage reverse while using PTO. It would make switching handle bar positions easier and make mowing easier in some spots.
